Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
When I activate my panel switch for my bilge pump I blow the 5 amp fuse in the fuse panel. Any suggestions as to where I start to diagnose this problem will be greatly appreciated.
Check the pump and make sure it does not have something inside stopping the pump from turning.
Turn it by hand and see if it turns freely.
Also Check the wires to the pump and make sure they have not worn a bare spot where it can hit some metal.
