Hello:
Im trying to repair my Mercury Power Trim. It is 3 rams, Design I, Square motor 3 cables. Sometime ago the oil reservior got broke and saltwater entered to the system. The oil color turned pink. I flushed the whole system including disassembly the cylinders and pressure release valve. Now the Power Trim is working with dificulties. The up movement takes a lot of time but it do the job. The down movement is performing as normal, I think it is due to the engine?s weight. The system doesn?t have any external leaks and the engine don?t get down unless the down button is pressed.
I think the motor and pump are good because the unit moves full up and down.
Can any of you please let me know if there is an schematic or a drawing where the internal parts are explained (part list). I would like to know if there are internal valves or springs that can be stocked.
Mercury 150 HP Black Max S/N 0C27152
Thanks to all
Thanks to all
