boat beast
- Feb 5, 2010
- 9
I just had both my DP outdrives serviced due to the shift cables siezed and a small water leak through the starboard out drive hole. The shop replaced the shift cables,u-joint bellows,yoke seals,yoke carrie o-rings,ram bushings,gromet bushings, and new GL5 oil.
I picked up my boat and paid $1,700 and headed for the ramp......Now both outdrives leak and the owner of the shop came down to the boat and says he thinks its the exhaust y pipe and wants to remove both motors at a cost of $2,000 just for labor.
I looked with a mirror and light and I don't see the water comming in from the exhaust y pipe. It looks as though the water is comming in from deep back in the transom hole.
Please help if you have any ideas as to what could be the cause of the leaks, now that it leaks on both motors.
