Question about quicksilver control unit swap out
Daddy Grace
Hello folks.... I've searched all over and even posted in the Force Outboards Forum as that is what type of motor that I have but I've turned up no help so hopefully I'll find some advice here.
I'm swapping out my old quicksilver commander 3000 control unit for a brand new commander 4000 control unit and I've got a question for your consideration and possible help.
Will the existing Generation 1 control cables work with the new Generation 2 control unit that I've just purchased and if so is it a direct changeover or will I have to make adjustments to them once installed....
Thank you folks (in advance) so much for your help!!!!!
Chuck Holt...
Mercman225
Re: Question about quicksilver control unit swap out
If your new control is Gen 2 then your cables will not work. Is your control box a concealed mount or panel mount, and was the old control a old teflex or an actual mercury control cause that will make a difference also.
Daddy Grace
It is a panel mount... it's been removed and discarded and as for the original manufacturer... I'd ASSUME that it's an actual mercury control as the boat is a 2000 Procraft 170 Combo and the engine is a 1999 Force. A little tiny ball bearing wore a groove inside of the shifter housing thereby disengaging the neutral safety switch unless you shifted into reverse. I took it completely apart and even considered filling in the worn groove with some sort of metal epoxy or something. I ended up stealing a brand new Gen. II Commander 4000 off of Ebay for 85.00 so here I am. I also am assuming that the trim switch from the old shifter will work???? Thanks for your input and anymore will be greatly appreciated.
Daddy Grace
I'd say that this is about the "no throttle cable issue havin'est" forum I'd ever seen.... :rolleyes: Now checking for a pulse... Is there anybody in there??????????
fishrdan
I thought Mercman had it covered, GENII shifter won't work with older cables, you need replacement GENII cables. The GENII cables don't have the "barrel" on the shifter end, just a groove cut around the cable end. If you search for GENII mercury cables on the internet a few places will show the difference. I got my GENII cables off Ebay, $15-20 a piece.
Does your 4000 shifter have the trim switch built into the handle? I'd assume you can adapt the trim switch in the 4000 shifter to work with your trim system. I didn't have problems, but was working with a Mercruiser I/O.
Daddy Grace
Awesome!!! That was perfect sir!!!! Thank you for the help... us non-mechanic types sort of need it spoon fed just like that. :D Thanks again!!!!
