Mark Allen
- Feb 16, 2010
- 4
Hello,
Long time reader, first time poster
Anyway, I'm working on a 60hp 2 cycle for a buddy of mine. I'm an auto mechanic, so I'm good with diagnosis/engine work, but the 2 cycle is giving me a few problems.
I had the engine at my house for a few days, and got it to run decent, but only when I retarded the timing all the way. I literally had to take the screw out of the adjustment linkage, (obviously not normal), but it ran fine like that. Revved up quickly and smoothly, up to 55k rpm. Obviously, the engine was not in the water, so the engine had no load.
Yesterday, we took the boat out on the lake for a test run, and it had no power. The highest it would rev was about 4k rpm. I'm guessing the power issue is from the timing having to be retarded so far.
The engine then died about 2min at full throttle. It starts right back up, and idles fine. IT even runs "alright" at part throttle. But, then we tried full throttle again, and it dies suddenly.
I tried moving the timing lever with my finger, and the engine dies instantly at any rpm or throttle.
I'm guessing the stator is toast... But could it also be the ignition "box" on the side of the motor?
Any thoughts?
Thanks,
Any thoughts?
Thanks,
