Interchangeability
ezrollin
How much interchangeability between 70 hp Johnsons and Evinrudes,interchangeability between what years?
Faztbullet
Re: Interchangeability
Johnrude 70's was changed several times during the years..here is some information that may answer your question:
1976-85.............3.000 bore
1985-01.............3.187 bore
Crank Interchange years
1976-82
1983-85
1985-89
1989-92
1993-98
1999-up
Around the early 80's the block design was changed to accept the 'plug-in" style pack and coils moved to the head,several mounting bosses were added and relocated on the block . Also there are several different models of carbs.
willamettejeff
Your question is way too general. If your talking between Johnsons and Evinrudes for any particular year, then they are almost completely interchangeable. If your talking between years, then it depends on the part being replaced. I was able to put the complete ignition system including the mounting bracket salvaged from a 1989 60hp Evinrude onto my 1978 70hp Johnson with only needing to grind down some unneeded bosses and adding 1/2 spacers under where the bracket mounts. The mounts for the later ignition bracket were there on my motor although not used by the original ignition system. All works great including the T&T relays that came on the bracket eliminating the need for a separate T&T relay box. Ended up with much better spark and much improved, more readily available, and less expensive modular design components. Also, put a 1988 gear case on the same motor. Sometime later they went to a finer spline at the top of the drive shaft, so can't use those. Added Tilt and Trim as well. Those units are compatible between many different horse power motors from 1978 to 1995. Changed to Fast Strike T&T in 1996 that is not backward compatible.
So, really depends on what your needing (or wanting) to replace.
willamettejeff
Despite information in the Gearcase Compatibility chart referred to in Tash's post, a 1978 70hp Johnson will take a gearcase up through 1988. In 1989 the 4 spline drive shaft was changed to a much finer spline that will not fit into the crankshaft of earlier motors. The gearcase part number (except for being superseded later including 1981) remained the same from 1981 - 1988. Other than swept back fin don't know what else changed from 1978. My motor runs great with a 1988 gearcase and in the same RPM range as the original 1978 gearcase with the same prop. So?????
