RE: Floor repair 1994 Capri 1700
harleyfatboy
Greetings all,
RE: Floor repair 1994 Capri 1700 ? Outboard Motor
To my horror I have discovered that I need to replace 2 sections about 3x3 portions of the stern floor area where the plywood has rotted. I have determined that the stingers and the transom area as well as the remainder of the deck appear to be sound. The worst area is under the back seat battery storage section. I am going to completely gut that section of the top skim glass and wood. So, having read some of the threads on this subject I am getting a sense of what I am up against, but I am a little overwhelmed. I think I maybe fortunate here that it is not as bad as it could be, however, I am new at this and determined to fix it properly. So, I have a couple of questions for those of you in the know, and experienced.
1. After removing an appropriate section of plywood and foam, do I need to remove the foam from the whole stern area even if it is dry? Or can I take out amount of what I think I need to in order to tie into existing structure to secure new plywood.
2. What similar foam material should I use to fill the hollow areas with?
3. After I have laid down new wood and fitted what is the best way to secure it solid?
4. Also, what material should I use to seal the wood afterwards?
5. And finally, can I re-carpet or is there any other flooring that would work better?
I am a little worried about how I should approach this project considering I have no help and totally new at it. I would be grateful for any suggestions or links to threads etc.
Your wisdom is much appreciated.
Thank You!
Harley.
oops!
Re: Floor repair 1994 Capri 1700
hi welcome to i boats....
there are a gazillion threads on this very subject.
and the very same boat.
i think you need to spend more time reading here.
start at the beginning of the hull extension thread....it has all you need...including fiberglass instructions and mixing ratio's
and what to cover your deck with.
however in the completed projects forum......jason j's skanky beast revisited....is great.
the answer to your question is simple......take away as little as you can.....duplicate what was there....and glass it all back together.
however....im sure there is more water and rot in there than you think.
if you can wait....ill be doing my bayliner's decks and transom in about a month
oops!
hey....your in bc ....where are you.....i can help, if you are close you can come look and see a boat in that construction phase.
harleyfatboy
Hey, Oops.
Thank you for your replies. Yeah, I guess I am going to have to do some serious reading. If I sent some pictures would that be helpful?.
BTW, I live in Chilliwack.
Regards.
oops!
yeppers....pics are allways helpful.....
hmm.....i think there are two on going projects in the "whack" area....i think one is in aggisis. ill try and track them down for you.
if you are up in kelowna.....let me know....
in the mean time.....read lots here....your questions will answer them selves.....but of course we are all here to help.
my keyboard is whacked.....if it didnt take so long to type stuff id run down your question list right now!
cheers
oops
harleyfatboy
cheers
oops
Thanks for your help -In addition to some reading - I will do some more cleaning out this weekend and take some shots and post them. I hope I don't
find more than I bargained for after digging deeper.
Regards.
oops!
post everything that you see....we can walk you right thru this.....no problem !.....there are some really good restorers on this site.....and the mechanics are... well...just the best in the world imho.
