Unfortunately, i need to replace a freeze plug on my 4.3 liter mercruiser engine and i'll need to remove the RH motor mount to do so. I have stared at this for days walking through the necessary steps to do this and wanted to see if i'm on the right track.
-Remove outdrive
-Support engine with wood block and bottle jack at front edge of oil pan
-Loosen RH mount at block and hull stud
-Jack engine slightly to relieve pressure on mount and hopefully work mount out of position
-replace freeze plug and re-assemble
Is there anything i'm missing? If i have to remove both mounts, how far can the engine be jacked up without damaging the transon or gimbal assembly?
Any advice would be greatly appreciated.
Thanks.
-Remove outdrive
Thanks.
