Hi All. I have a 2003 carburated 150 hp Mercury engine that is hard starting when it is cold. After getting started, it runs fine and starts again immediately. The problem just started and has happened twice. I have changed spark plugs and the fuel filter. The primer seems to be working fine. It is clear to me that it is not getting gas to run. I can manually prime it and it will run for a second or two but then it dies. Up until a day or so ago, it was starting and running fine with the same fuel so I don't think that the fuel quality is the issue. Any ideas on what I should try next???
