9.5 lost spark
robert53a
Had a fine running 9.5 1973 model that lost spark on top cylinder. I pulled the fly wheel and found all of the stator plate screws loose. all else look fine. points and condensor look fine. i cleaned and reset the gap in all and reasymbled and still have no spark in the top cylinder the coils look brand new as well as the points. How do i check this flaw or just use the shot gun approach and change everything. Any sugestion would be appreciaited. The manual tell you how to change and check cleances, but gives no tests. Thanks....Robert
bktheking
Re: 9.5 lost spark
Check stop circuit to start, disconnect it. Still nothing- Clean and adjust points and test. Swap coils to test if still no spark. If no spark on the same cylinder points and condensor need replacing. Could be a non seated wire in the coil as well.
robert53a
Re: 9.5 lost spark
Thanks for the quick responce. I'll give thoses suggestion a try.......Robert
1946Zephyr
Re: 9.5 lost spark
Swap out condensors too and see if you get spark in the other cylinder. I would try this first, before swapping out coils, It's just a tad easier.:D
How's your arm BK?
bktheking
Re: 9.5 lost spark
How's your arm BK?
I go tomorrow 11am to get the perm cast, 5 weeks of no outboard fiddlin :mad: and all this and all my parts arrive. Needless to say im pissed about the whole thing , now its a waiting game. Thanks for asking, maybe back to work next week.
robert53a
Re: 9.5 lost spark
Hi, after removing the fly wheel, found a loose stator plate, missaligned points ,and chaffed kill wires. I have a tune up kit and will install. have relaced the kill wiring. that will leave onlt the coils.....Robert
