spark plug ? 1989 Evinrude 40hp
bobjoe1
I have a 1989 Evinrude 40hp with the vro disabled and mixing gas. I went to local dealer and asked for the QL78YC plug and he said that I should use the QL77JC4. Any remarks are appreciated. I put the QL77JC4 in and seems to run ok but would I get better performance and milage out of the QL78YC
ezeke
Re: spark plug ? 1989 Evinrude 40hp
The current listing for the 1989 recreational 40HP motor is the QL78YC.
bobjoe1
Thanks but I was curious as to whether I would now need a suppressor plug since I disconnected the vro
Howard Sterndrive
I don't see the connection between VRO and plug... I run the standard plug in my 1990 40HP and I premix. I get no excessive fouling. Use good oil and tell the dealer you just want the plug you want.
bobjoe1
thanks but according to the charts if you dissconnect the vro you don't need a suppressor plug which is a Q in front and I seem to be using a whole lot of gas.
Howard Sterndrive
charts?
check compression, check spark, run some seafoam through
unless you changed to a supression plug at the time fuel consumption increased, I don't see the logic
both plugs you reference have the Q so they're both suppression plugs
QL78YC is the one for your motor
