Black as
- Feb 22, 2010
- 417
Hi Guys
Need some advise, I imported into Australia a 1988 2250 cobra Capri with a 350 chev along with a cobra stern drive. Over the past month I am giving the boat a complete work over checking everything before it hits the water. About 2 weeks ago I checked the stern drive oil level and it was down about a 1/2" so what I did is drain the unit and replaced it with new oil. So from when I bought the boat and then receiving it took around 6 months and there where no leaks upon arrival, but since I've put in the new oil I have found a few drips on the garage floor, so I removed the prop and had a good look and tightened the 4 bolts inside the lower leg and got about a half a turn out of each bolt. But when I received the boat there were no signs of oil in the lower leg??? The oil I used to replace the old was a quicksilver brand 75w90.
The bottom inner casing with the 4 bolts attached looking at drawings show a ring seal on the casing, may be this is the cause, not sure? can anyone give some advise, I have some ideas but is this common and what is the best way to tackle this.
