hi, yesterday I got my boat in the river and after been cruising for some minutes I when back to idle and notice a knocking noise coming from the motor , went back home and checked the compression and in one bank is 100psi and the other 120psi, they where all 120 psi before, also noticed that the plugs where very dry , like if the motor is not getting oil...I have a 1997 130HP Johnson 90 degree with the VRO , and I would like to disconnect the oil pump and premix the gas , that I really preffer and I think is more secure, having two cylinder with 20psi low still is no that bad, because the motor still runs very strong...there is a way to do this ?..any help thanks
