1973 650 mercury no spark
flip123
Hi all
I have an issue with a 650 3 cylinder motor
no spark ran through the test method i found here
power on red all the time
power on white and black when ignition on
no output on green
bridge blk and white and black no spark when bridge white and black and black to blue no spark
bridge black and white to blue get spark at spark plugs
the question is is it the cdi or something else that causing the no spark
thanks
flip 123
in oz:eek:
Laddies
Banned
Re: 1973 650 mercury no spark
Here's a simple test fot the system.
flip123
thanks
i try this
another question
is the trigger inside the distrbutor
and is the black wire the trigger wire
Laddies
Banned
The trigger and dist housing are 1 piece and must be replaced as a unit all 3 wires from the dist are wires that are connected to the trigger.
flip123
thank
i will run this test
and see if it the cdi or distributor
i let you know the outcome:)
crappiejig
flip 123 check your private messages.Update,looks like the PM service is down,but I have a spare switchbox if you need it 332-4796.
flip123
all fixed was the pick up in the distributor
thanks :p
