broken key in ignition
cajunfamily
I just got a boat from my dad and the key is broken off in the ignition. It is an evinrude power pilot control box, It is a fisher marine 16' aluminum bass boat. I believe it is a 1985 or so, but the motor has been replaced with a johnson 55 in about 1998. The key has a cap on the top of it that fits around the keyhole. I can still start it just by placing the cap end in place and turn. I would like to replace the key. Where would I find one or is there something else to do?
cajunfamily
Re: broken key in ignition
Thank you for your reply. It this a pretty standard part. There is no numbers visible on the switch. A six pole switch should work? I will give that a try.
