tluchterhandt
- Mar 2, 2010
- 6
My last post I changed the impeller and ended up with linkage out of adjustment. Well I got that figured out and walked in the shop and notice a small amount of water and oil on the floor, and some oil on the skeg coming from behind the prop. I drained the gear oil and there was water in the oil.
When I ran the motor prior to changing the impeller there was some evidence of oil in the water tank I used (just a film of oil lined the edges of that tank). I thought it was exhaust/fuel residue. What I am wondering now is if there could be something I did while changing the impeller that allowed for water to infiltrate the gear housing. All that I removed from the lower unit was the water pump housing and the impeller housing and impeller. I didnt even move the plate or gaskets/O-rings. I am suspecting that it is the prop shaft seals (2) but would like some of your inputs.
1998 Evinrude E25TELECB
Thanks!
Thanks!
