1966 Evinrude 18... too loud?
DaveGH
Anyone have any suggestions? Seems quite loud but maybe this is the way they are? Should I check anything or put foam? Thanks
kenmyfam
Re: 1966 Evinrude 18... too loud?
2 stroke outboards are traditionally not quiet !!! Get some ear plugs.
Welcome to iboats.
bktheking
Pipes save lives.......oops wrong forum :p
bktheking
On a serious note, i'm sure you've heard other outboards , does the exhaust sound like it's above water?
DaveGH
thanks for the welcome...
hmm, yeah, it sounds like maybe the exhaust is above the water. Although the motor is at a good height on the transom.
bktheking
Next time you have it out pull the cover and check for an exhaust leak.
DaveGH
thanks. It's out now, where do I look for the exhaust leak? Don't know these engines at all..
threedogs333
When did they change to through hub exhausts, in the seventies wasn't it. the older motors had the exhaust above water and made a far racket because of it.
