dropping the lower unit on 1988 100hp Johnson GT. Where do I disconnect the mechanical shift? Thanks
J jdgreen81 Recruit Joined Mar 8, 2010 Messages 3 Mar 8, 2010 #1 dropping the lower unit on 1988 100hp Johnson GT. Where do I disconnect the mechanical shift? Thanks
Gary H NC Fleet Admiral Joined Dec 1, 2005 Messages 8,972 Mar 8, 2010 #2 Re: 1988 johnson 100hp lower unit Have someone move the shifter back and forth while you look under the carbs down by the lower cowling. It will be a screw or a pin that connects to the shift rod. Not sure exactly what one on that year.
J Jeep Man Commander Joined Oct 17, 2008 Messages 2,803 Mar 8, 2010 #3 Re: 1988 johnson 100hp lower unit Welcome to the forum JD. You might want to re-post in the "Repair and Maintenance" section under Johnson Evinrude for better results. Good Luck!
