evinrude 40 hp 1964 impeller question
chestercheese
hello to all you good people
just wondering if anybody can help me?
i'm trying to change the impeller and water pump on my evinrude big twin 40hp,
i've taken all the bolts out, (that i know of?) but just cant seem to shift the gear box, there is a little bit of play but just wont drop:confused:, any help from you guys would be great,
many many thanks dan:)
ezeke
Re: evinrude 40 hp 1964 impeller question
I believe that you will find an oval plate held on by two screws, behind which is the coupler that connects the two sections of the shift rod.
Remove the bottom screw from the coupler.
You may need to use the shift lever to apply enough pressure to release the coupler.
lindy46
Also you have to remove the rear exhaust housing to get to the big bolt at the back of the motor. It goes through from the top and is hidden from view with the exhaust cover on.
chestercheese
hello
thanks for that info, yeah i've got the exhaust bolt off, i've taken the top bolt out of the gear shift as the bottom one has a nut and bolt and i cant get two spanners in there? does it have to be the bottom bolt or will the top one do? thanks for your quick replie:)
ezeke
Either will work. Usually you can move the shift lever to line it up.
When you put the screw back, be sure to line up the rod first so you don't lose the threads on that one as well. Those connectors are now listed at around $18. - without the screws.
chestercheese
hello again
when you say its hidden do yo mean the long bolt at the back of the engine just above the prop? i had to take the cover off to get to it, ive taken the top bolt out of the gear shift but the rod is still stuck, do i just need to give it a good old yank to seprate? cos i have got it to drop about 2mm but wont go any more, i think its cause the gear shift is stuck:confused::confused:
ezeke
See if you can spread the connector/coupler a little.
chestercheese
hello
yeah will do, i'll let you know how i get on tomorrow, thanks again for all your help cheers dan:):):)
chestercheese
hello
thanks for your help yesterday,
i managed to get the gear box off, just got to get these horrible screws out, not looking forward to that, they are only flat head screws and are very very tight, i'll let you know how i get on, or shall i say how many i shear off????
cheers dan
lindy46
Do you mean the bolts holding the impeller housing on? Soak them with penetrating oil before trying to remove them and hopefully they'll come out.
chestercheese
yeah but they are flat head (or spade heads) which will make things harder if they wont shift
chestercheese
hello
just to let you know, all three screws sheared off, left them soaking all night but did'nt help,
still i've drilled and tap'd them all so good as new, the pump hausing was really clogged and the ends of each impellar fins were broken off and stuck in the pump, so on the bright side, its all clean'd and just waiting on the impellar kit to arrive, any other tips on what i should do when re-assembling?????
cheers dan
tx1961whaler
hello
cheers dan
I've had to drill and retap most of the impeller housing screws on my motors....they are a weak spot in the design, especially for a saltwater motor.
lindy46
cheers dan
Make sure there is an o-ring/seal at the top of the driveshaft before re-inserting. Also, grease the splines at the top, but don't put any grease on the end of the driveshaft - just the splines.
