sputtering under load
mciaio
Re: sputtering under load
I had an engine do that when I had a cracked spark plug.
jonesg
could be fuel or ignition, choke it when it splutters, if it picks up you probably need to rebuild the carb with a rebuild kit.
kenmyfam
1995? 50hp evinrude idles fine. under load will sputter and not get on plane.any ideas?
Lot of ideas but most could be wrong without enough information. Best bet to begin with is a basic health check.
Compression
Spark
Fuel delivery
Spark plug condition.
Good base to begin with. Post results and we can all go from there.
tashasdaddy
totally agree with kenmyfam. trouble shoot before, buying parts.
bandannarob
thanks all. you all said what i thought. it idles fine and in gear,but when we try to throttle up it goes "vroom vroom miss"we will clean carbs\ re build tonight and post results
kenmyfam
Hope it improves things for you but are you giving it the other checks as suggested ??
jonesg
All you need to do to troubleshoot the carbs is stick two fingers in the carb throat to choke each one , find the culprit.
If pushing the key in has a more dramatic affect then I'd suspect the pump or anything that can impede flow, fuel tilter etc.
If none of the above helps, see if a timing light shows spark drop under load.
When I bought my outboard I watched a mechanic do this to find the problem, took a few minutes and he said power pack.
Yeh he did a compression test first.
I was just impressed how quickly he tracked the problem down.
And I would rebuild them all anyway if its new to you, that and everything else in the sticky file above.
