Suggestions for a mod.......
Jeep Man
Re: Suggestions for a mod.......
May sound "a little left field", but have you considered a vinyl cover held in place with velcro?
mcgyver
thanks, hated the look of the vinyl covers thus they were removed. Panels and hinges are what i'm thinking but can't wrap my head around how to mount ect. I'm thinking smoke colored lexan/acrylic and have looked for delrin type hinges, I would like to be able to pull a pin and remove the panels when I'm working on the batteries ect. i can't seem to find a hinge that meets the need....... anyone have pictures of what they've done? thanks
mcgyver
Thanks Bob, i'm actually considering not using hardware at all now. instead, the panels that will be 1-2" larger than the opening will mount by having a cleat on the top and bottom. Insert the top cleat first and then drop onto the bottom cleat which will hold it in...make sense? clean, no hardware to worry about, and won't be in my way when i service anything inside.....now to figure out the handles to insert/remove.....;-)
Bob_VT
you still need a latch. Hit the right wave and the hatches could pop open using the cleats ;)
mcgyver
Hmmm, your right....ahhh.... the search continues........foiled again!!!!
jspano
i would think fiber or tinted plexi glass, larger than the hole hindged at the bottom place low so that when their open they lay flat on the deck.
Bob_VT
You will still get your best deal on hardware here on iboats!
Spinnaker
Absolutely! The link to the ad I provided was merely an example. No way in hell I'd pay $30.00 for something I get for $8.00. Pirates I tell ya! :p
