Poor note taking--need to know where a hose plugs in Johnson 115
GatorMike
Ensign
I'm putting my powerhead back on and I have ran into a snag. Under the primer solenoid there are 3 hoses 2 small ones that go to the carbs and one large one. I didn't note where the larger hose goes (probably because I thought it would be obvious). Anyway I can't find where it plugs in, I suspect there is a reason I can't find it. There apears to be a small nipple inside the hose that I probably broke off when I unplugged the hose. That would explain why I can't find anywhere to plug it. Anyway I need to locate where that hose goes so I can make the necessary repairs. Can somebody tell me exactly where that hose goes?
ezeke
Re: Poor note taking--need to know where a hose plugs in Johnson 115
The large hose runs from the primer solenoid to the fuel manifold that also serves the two hoses running to the carburetors.
GatorMike
Ensign
Thanks, I thought that is where it went, must have broke off the nipple when I unplugged the hose.
tashasdaddy
you can get new manifold for the primer instead of replacing complete primer.
ezeke
Fuel manifold is part #0390465; click the thumbnail, please.
If you want the top for the primer solenoid, it's part #0437228.
