40 HP 1980ish NO SPARK Both Cylinders
bojango541
I have a 40 hp johnson. It's around a 1980 or so. I'm getting no spark in both cylinders. I'm guessing its not the coils since I'm not getting spark from either, but im not positive. Any suggestions? Also, is there a way to test the coils with an ohm meter? Thanks, Nick
EN2
Re: 40 HP 1980ish NO SPARK Both Cylinders
Unplug big red connector at powerhead, jump starter solenoid.{ red terminal to closest small terminal} Pull off spark plug leads,spark should jump 1/2 in gap. Bright blue snap. This way you have eliminated the key switch and kill switch and remote control harness as possible problems.
bojango541
Forgot to mention I already Tried that, and it didn't help, Thanks for the reply though.
EN2
What is your model number?
cheeky
Hi have you checked the points gap? I had no spark so I reset the points and spark plugs and that fixed it..
