During my last lake outing a week or so ago the tilt trim stopped working correctly and while it still trims/tilts DOWN just fine with the standard control on throttle, the trim/tilt UP function doesn't work, you can just hear the solenoid click.
There is power to the solenoid and if you manually bidge the two main posts on the trim up solenoid the motor trims up properly as it should...Thinking it was a faulty solenoid, I ordered one and replaced it this morning, but the issues continues.
Any help you can provide will be much appreciated, the weather is calling me to the lake, but the trim issue makes it a bad idea...
-Travis
-Travis
