Re: Thru Hull holes
i plan on using dowel material to fill the holes in my transom, drill to fit the dowel dip it in epoxy or poly resin, drive it in, like no hole was there, then fix the finished surface w/ paint or gelcoat. im doing a complete rebuild though, in your case may be a little extreme.
