Re: best prop pitch on jhonson 88 spol
You really need to have a starting point. What prop is on it now? What rpm do you turn at WOT????
I am pretty sure that motor isn't supposed to turn over 5500 rpm if you want to keep it in one piece so you need to see what rpm you are at now and then you can adjust.
As a general rule you can anticipate a 250 rpm change per inch of pitch if that helps. But there are other factors to consider like diameter, number of blades, etc......
