77 Chrysler 75hp OB-Shifts into gear hard-Jerks boat
argeldeggy
Hi Everyone,
I have a 77 Chrysler 75hp, I've been having issues with it when shifting forward or reverse. It shifts into gear pretty hard and jerks the boat. What could be the problems? I've looked at my Clymer's Shop Manual and have not found any trouble shooting on this issue. Please Help.
Thanks in advance
Argel
foodfisher
Re: 77 Chrysler 75hp OB-Shifts into gear hard-Jerks boat
Don't know your specific motor but a clunk is normal on a force. Sort of like an older Harley. Jerking the boat is unusual. Are the RPM's too high?
argeldeggy
I will check the idle RPM, how fast should the RPM be? Thanks for Reply. The other day It clunked into reverse so hard I saw the motor jump back and then forward which jerked the boat. Going into reverse clunks into gear harder than forward does.
Thanks again for the reply..
Argel
Frank Acampora
If the idle speed is correct: 700-750 in forward gear, in the water, about 1000 in neutral then
Check the distributor drive belt tension and check to see that the distributor moves freely. Either a too tight drive belt or a dist. that is binding will cause an interference in the shift linkage and the engine either will not go into gear, go in very roughly, or not come out of gear. Sometimes all three.
The drive belt should deflect about 1/8 inch when a .010 feeler gauge pointed like a finger is pressed in the middle. That is, the belt should deflect that much before the gauge bends.
argeldeggy
Thanks for the info, In neutral RPM's is set at almost 2000 rpms. Ill see if changing that will make a difference. I think this is the prob, Ill keep you posted.
Argel
