It's a peak voltage meter... Normal meters read sinewave AC. A peak meter will read the peak value of the voltage signal even if it's not a sinewave, like an outboard stator or trigger output. And that's where you NEED them. Measuring resistance is, at best, useless. You need to be able to check their output with a DVA meter.
