I just picked up a used motor, 1999 Johnson 25 horse with electric start.. took a while to get it started, but now that I actually got it going, the only way to keep it running is a little starter fluid in the carb. I checked the fuel line and the strainer/filter, and fuel came up to that when I squeezed the ball. so some how the carb is not getting fuel. I thought about taking the carb out and cleaning it and the jets to see if that helps. I can't get the carb off cause one if the nuts is behind the starter and I can't figure out how to get the starter off with out taking everything apart. Any ideas about the fuel problem? fuel pump? how do I know? thanks again
