Re: starter sticking
It's possible that when you fix the slow cranking problem you will get fire to your plugs. If the flywheel isn't turning fast enough you may not be creating enough voltage in the stator to fire the plugs.
Check and make sure your battery is fully charged. A battery tender over night propably isn't enough to do the job. Get at least a 8 amp charger and let it charge until the amps from the charger drops to around 1 amp. Check the voltage, should be around 12.5 or a little higher.
If it still turns over slow, do a voltage drop test on the positive cable from the battery (checking at every junction in case you have a battery disconnect switch) to the starter and then from the engine back to the battery on the negative. I had a problem with mine turning slow and found that the negative had a bad spot in it. I replaced the cables and it made a huge difference.
Durwood
