Re: Compression questions about 1.5 & 9.5 HP Johnsons
I'm using two printed resources - a SELOC manuel and a CD I purchased on line. Both say the same. The early model has the spring (SELOC pg 3-27) (CD version pg 4-31). Whereas you are saying the spring is on the later model.
I'm getting more confused, so let's go to the bottom line. My carburetor has a flexible cable needle valve which is connected to the carb thru a small packing nut, which may or may not have packing. As it is beginning to appear this is a previous Rube Goldberg, could this be the source of problems? Should I order a spring to make it original?
Actually, now that I think about it, I would prefer to put it back together as the later version under the assumption that is an improvement Johnson made. But, which is the later version? Do I go with the manuel or your recollection?
