Help connecting GPS to DSC VHF
DiggersC5
Good evening
I've struggled with this (simple) wiring problem for too long
I have a Garmin 178C Chartplotter / Finder and a West Marine VHF 600 fixed radio. Both are a couple of years old, but should work together.
The wires to the two harnesses:confused: don't have the same names or colors.
I'm including scans from each manual and am hoping that somebody can tell me which wire should connect to which wire. I think I've tried every configuration except the right one and keep receiving a "check wiring" error message on the GPS.
Here's a link to scans of the wiring harnesses.
Desktop
Your help would be appreciated
jhebert
Ensign
Re: Help connecting GPS to DSC VHF
Connect the NMEA Data (+) OUTPUT from the GPS receiver to the NMEA DATA (+) input of the radio.
If the Radio NMEA DATA has a (-) input, connect it to the power ground of the GPS receiver.
DiggersC5
Thanks for the note.
I had considered that as the GPS doesn't have available negative leads that are available to match the negative leads from the radio wiring harness.
I'll give it a try and let you know what happens.
I appreciate your help.
Doug
jhebert
Ensign
The use of the "+" and "-" notation regarding serial data NMEA signals does not refer to polarity, that is, they are not "plus" and "minus" as you would think of a voltage.
The "+" indicates the non-inverting input; the "-" indicates the inverting input.
The GPS is the data signal source, and the data signal is not a differential signal. There is only a single wire on which the data signal is available, and it's signaled with respect to the power ground.
The radio is a listener or receiver of the data signal. It has a differential data input, with non-inverting and inverting inputs. You connect the inverting input (noted by the "-") to the power ground.
DiggersC5
It worked!:D
Thank you very much for your help!
1 nagging item off my list, and another 20 to go.
Have a great day.
