hubs bearings and seals
vwluv32
I have an older boat trailer that needs a hub kit. The problem is the spindles are 3/4" with a 1 1/8" lip for the rear seal. I would go with integrated hubs, or a hub kit. Anything for 3/4" seems to be hard to find. Any suggestions on where to get these things?
Thanks,
Chris
kenmyfam
Re: hubs bearings and seals
Go to an actual bearing supplier as opposed to a dealer. usually much cheaper and readily available.
I have a great local place called Canadian Bearing. They have never let me down yet. take the old one with you if you can for them to reference.
Good Luck.
lckstckn2smknbrls
My trailer has 3/4" bearings. If the time comes I need new hubs I will replace the axle and hubs. I did find the bearings and seals kit at Farm n fleet $14.00 each.
vwluv32
I have a weird type of torsion axel, gonna require lots of work to replace and then might not be able to do it right.:(
