I recently spent a good bit on some work done by a local marine dealer. It was work to remedy an overheat situation that I had. The dealer ended up putting a new water pump, new overheat sensor, and had to bead blast some foulant in the heads on the water side. There was a bad gasket in the midsection that was also replaced and the poppet valve was rebuilt. I do not run therms in this engine and have not for over 15 years. This overheat problem just happened recently before I shopped the engine.
Since the repairs, I am not seeing much water pressure at idle (on a new gauge), it barely comes off the stop pin. The engine does not overheat at 5500 rpms and has plenty of water pressure (22 psi) and on throttling back I can see the pressure swing indicating the poppet valve is functioning best I can tell anyways. The overheat horn comes on when I try to run the engine at planing speed around 2600-3000 rpms. When it blows, I am indicating around 10 psi of water pressure.
The dealer said the water tube was OK and the top and bottom seals on it were good.
Does anyone have any idea what was missed on the repairs? Defective water pump repair? The dealer is working the problem but I just wanted to know from some of the forum participants.
Thanks for any help provided.
JimDD
JimDD
