Dave Patterson
- Jul 8, 2009
- 7
I recently purchased a boat with a 290A outdrive and an AQ271C engine. I have attached a picture showing where the raw water intake from the drive has been tapped into with a shutoff valve from the intake and a capped off stand pipe with another shutoff valve. Is this setup meant to make winterizing easier? I have removed the outdrive to clean and paint and am wondering if I can use the standpipe as a water supply so that I can run the engine on land or would the water pressure from a hose damage the water pump impeller?
Thanks,
Dave
Thanks,
Dave
