Re: Removing steering cable from outboard
disconnect control arm from cable(#2 photo) you can turn the wheel all the way to make access easier. Then unscrew retaining nut (photo #1) and pull cable as free as possible, you won't be able to completely remove just yet. You can turn wheel oppisite way to shorten end, now get in the boat and pull whole cable in as far as you can, you may not be able to go much as its going to bind on the radius, but every little bit helps. Once as much slack you can take is out you will probably have to slide the motor toward the port end of the transom to free the cable the rest of the way. When you reset the motor set it on that same side to save having to slide it again. Once the O/B is off that is a great time to inspect/lube cable where possible and if the transom boot that it slides thru needs to be replaced do it now as well, so you can use a one piece instead of a split boot. Get a good end wrench for the retaining nut its starting to get pretty buggered. Good luck.
