What is this. and how much do they cost?
padleout
it is mounted at the top of the intake on my 1983 115 hp johnson. there are three tubes connected to it from the carbs. while i was attempting to pull the tube off i broke a plug to hold one of the tubes. just wondering if i could get some help
mikesea
Re: What is this. and how much do they cost?
that is a primer assembley,it basically shoots raw fuel into the eng ,it replaces the choke system.the piece you broke is replaceable. would need to either get a used one,0511807 is the part numberl,or get a whole used unit on ebay,or new for $16.00from an evinrude/johnson dealer,its held by 4 screws ,here is a lik to the BRP website ,hopefully it comes up OK.
http://shop2.evinrude.com/ext/index.aspx?s1=bf6ad09c53cead335fcfd8a6471c0f7f
padleout
thanks a million guys. just trying to get this thing up and running for this season
Proselect
I have this assembly on my motor as well with the shrader valve. This unit is what shoots fuel in when you push in the key, right? What is the shrader valve for? What is the red tab/lever for? Boy I need to buy a manual.
bktheking
Red lever- it's to manual prime for rope starting, leave it where it is for normal use
Shrader valve is used for connecting OMC fogging oil with the fitting onto the shrader valve for winterizing.
Proselect
just curious which way it is suppose to point for normal use.
tashasdaddy
it is also used with BRP engine tuner, to decarb you engine.
ezeke
The schrader valve is very helpful for fogging the engine for seasonal storage as well as for the annual de-carbon treatment.
A $2.00 OE injector hose part #0763644 fits most OEM aerosol products as well as SeaFoam's Deep Creep that is popular with some forum members.
http://shop.evinrude.com/dyn_prod.php?p=763644
