85 hp force battery needed?
mick97
Hi,
I just bought a 1985 bayliner capri with a 85 force motor yewsterday.
Does any one know what type of battery I can use in it?
It has a stereo also,but not sure if that makes a lot of difference.
I was wondering what voltage,and size.
Im new to the big boat world..lol
Could I just go to walmart and get one?
Thanks ;)
Scotty
jerryjerry05
Re: 85 hp force battery needed?
Yes Wallyworld,Any battery 450CCA or over.If you are gonna listen to the radio after you shut off the motor then get a bigger battery up to 1000CCA
But to be real sure you have a battery to start with,put in a second and a battery switch.That way (if you can remember to switch it on and off)you will always have a good battery.J
mick97
Hey thanks.
It doesn't look like it had a regular car battery in it by the cables.
But it could of been a side mount battery I guess.
Thanks,
scotty
john from md
Walmart carries the Marine Maxx batteries. Get a Group 24 or 27 and make sure you check the water from time to time as that engine only has a rectifier and not a regulator. It will boil water out of the battery as it normally runs at 16volts.
John
mick97
hey john,
Thanks for the info on that.Always nice to hear from someone who's been there :)
Going out tomorrow to check it out.
I'll post again after I get er done.
Thanks again,
Scotty
john from md
If you use the boat alot and also have electronics on it, I suggest that you convert to a regulator. The procedure is located in a sticky about high voltage at the beginning of the Force forum. This protects your electronics and makes your battery last for a few years.
John
mick97
Good idea.
Thanks for all the help.
Scotty
