1972 Evinrude 50hp motor question??
FUN2BOAT
Motor starts and runs only in forward.........when I try to put it in reverse, it blows the fuse by the starter and the motor dies. What could be causing this to happen. I just purchased the boat and would love to get it on the water soon, but am new to boats/motors. HELP!
fireman57
Re: 1972 Evinrude 50hp motor question??
If memory serves, that is what they called and electric shift model which means they had solenoids that do the shifting for you. The solenoids are getting harder to find and more costly. I am guessing that you had one go bad. You might get lucky and just have a bad wire to it.
tx1961whaler
You have a hydro-electric shift motor. Ones of the shift wires may be shorted. Sometimes happens when re-assembling after a water pump change.
From (J. Reeves)
The shifting setup of the lower unit is what's called a "Hydro Electric Shift", which is quite complex consisting of voltage being applied to solenoids in the lower unit which in turn change oil passages via a oil pump that supplies various pressure on a spring loaded shifter dog. The wires leading to the lower unit (at the powerhead) are "Green" and "Blue". The engine must be running or cranking over in order to shift out of forward gear.
You CAN NOT use HI VIS lube in that lower unit. You MUST USE what OMC calls "Premium Blend" lube, commonly called "Type C". (A thinner lube)
Note: The engine must be running OR have the driveshaft turning by some other means in order for the engine to shift.
In neutral, you need 12v to the "Green" wire.
In reverse, you need 12v to both wires, the "Green" one and the "Blue" one.
In forward, there should be no voltage to either wire. (The spring loaded shifter dog forces the unit into forward gear)
To check the lower unit for proper shifting to make sure you have no trouble there, remove the spark plugs to avoid problems and to allow a higher cranking speed.
This next step eliminates the actual shift switch in case problems may exist there.... Disconnect the blue & green wires at the knife connectors (the rubber insulated boots) leading to the lower unit at the powerhead, then using jumpers, take voltage direct from the starter solenoid to apply voltage to the "Green" wire for neutral, then both wires 'Green" & "Blue" for reverse (Remember the engine must be cranking over in order to shift).
With no voltage applied, the unit should be in forward. No need for a ground jumper... the lower unit's already grounded.
F_R
Disconnect the blue and green wires back by the powerhead. Now shift the control through the gears. Does it blow the fuse? If it does, the short is somewhere in the control or the wires beween the control and where you disconnected them. Hint: the blue wire is reverse. Green wire is used for both reverse and neutral.
However, if it does not blow the fuse when disconnected, but does blow when connected, the short is somewhere between the disconnect and the solenoids in the lower unit.
Once you narrow it down this way, you will know where to proceed with further troubleshooting. Don't just assume "bad solenoids". That probably is NOT the problem--but could be.
trbarret
I had the same problem, the previous owner did a water pump change and crushed/severed the green wire near the water pump which caused my motor to run in foreward only.
very well could be the wires, should have 12 vdc in reverse and neutral on blue and green wires. both wires in reverse and on in neutral if memory serves me right.
If it is a broken wire get the self sealing water tight butt connectors.
t
FUN2BOAT
Thanks everyone, I'll try to tackle this over the weekend and see how it turns out.............will post update or more questions as needed! Appreciate all the advice.
FUN2BOAT
Okay, so now the fuse by the starter pops/blows when motor is not running when I push the reverse button. Same happens when motor is running. Replaced it with a 20amp fuse and is still popping. What might be causing this?
tx1961whaler
The blue reverse wire is shorted to ground somewhere.
