Hello. This is a new to me 89 Blackmax 150xr4. When I bought the boat I didn't bring my compression tester with me because I didn't think it worked. It's a really cheap POS but I tinkered with it and it does work.
I dont' trust the accuracy of the numbers, but I believe the consistency between cylinders should be relatively reliable. The top starboard cyl is slightly lower than the other 6. All the others read around 100 but this one only went to 80. The gauge doesn't even rest at 0 so like i said, I don't trust the actual numbers but from what I hear consistency is more important anyway.
My question is, should I run it or build it? I'm telling myself it's a stuck ring because that's what I want to believe and a decarb will take care of it. The motor has been sitting for a couple of years minimum. I wont be terribly heartbroken if the answer is rebuild it, but I really wanted to fish this boat this year and I know I won't have time to rebuild it myself in time and I like to do my own work. It's not the money that hurts, its the time.
My thoughts were to get it on the water with a tow boat if necessary and a can of sea foam and do a good decarb and see if the numbers change.
I've not built a boat engine, but done many cars and the basics seem the same. I have all tools necessary unless there are some special tools.
I bought this boat super cheap as a project because I just love taking old things and making them new, I was just hoping to enjoy it a bit this year first. So what advice can you give? Thanks!
Adam
Adam
