Re: Them's the brakes--Trailer Brake Questions
I went through a brake rebuild 3yrs ago. From my research back then, disc brakes do not work as well as drums if the boat is below about 24'. Disc brakes need more pressure from the actuator to be as effective as drums which means the boat needs to be heavier to exert enough pressure on the brakes to actuate them.
I would definitely prefer disc brakes over drums if you boat in salt water. I have had to replace the drum kits about every 2yrs due to salt water corrosion. I would assume disc brakes would last longer due to being easier to fresh water rinse.
Also, you will have the backing up problem with both disc or drums. For the kits I buy, before backing up, you just put a lockout pin in the tongue and it disables the brakes. This is convenient since all I have is a 4 wire trailer harness.
