Need Power Pack Wiring Diagram 2000 Johnson 70 HP
HOUSECAT552
I need a wiring diagram for a 2000 JOHNSON 70 HP Model # J70PLSSD POWER PACK also need voltage and ohm values for Pack so I can trouble shoot. No spark on all 3 cyl's . The pack looks perfect no heat damage or burnt smell. Started fine ran perfect shut off. Would not start next time no spark on any cyl also nothing on any coil.
tashasdaddy
Re: Need Power Pack Wiring Diagram 2000 Johnson 70 HP
have you check the coil, that is more likely with just one not firing. you will most likely need to order a service manual from Dealer or BRP.
