Hi
I have a few questions regarding my 1986 90hp VRO
First question I have is, As you are looking at the motor from the front, on the top left, there is a small Red Lever/switch. What is this for? And what position should it be in?
Second question. 2 years ago I replaced the VRO pump. Motor has been used very little since.
When motor is in gear and idling while motor is trimmed up in Shallow launches etc. It does not want to run real good. Acts like its starved for fuel. prime it alittle bit (Bulb not soft, but not rock hard either) restart and its fine. Trim motor down and problem goes away.
Motor runs just perfect at W.O.T.
Thanks for any Input!
