bbbaldridge
- Aug 4, 2007
- 2
My first post Repairing water pump on 69 9.5 hp
Following shop manual for 9r69s, but when four bolts removed, lower unit drops only about 1/4 inch. Not enough to get a screw driver in to disconnect shift connecter. How do i get it to drop further? Also the manual says to put motor in foward gear. In forward lower unit does not drop at all. The manual says nothing about disconnecting anything at the top of the shift rod and I see nothing that could be adjusted to lower the bottom unit.
