Hello. 1982 Mercury 115hp Tower of Power with serial number 6093314. Has an outboard jet on it. Just recently pulled the Jet off and put on new impeller on, cleaned up gates, and installed a new water pump kit. Now, I'm a little lost on boating machanical part names, but I desperatly need a new lower end bearing....the bearing that needs to be greased evertime the jet is used on the water...its below the water pump, and above the Outboard impeller. Holds the drive shaft in place to the Outboard jet housing while turning the Impeller. Need to find the Complete kit part number or just the bearing part number. Even the Mercury Dealer I called is having a difficult time finding what I need. Not sure why??? The part number that is on the original bearing is (Federal 5305H). I would prefer the entire kit, but just bearing will do. The Mercury dealer thinks I need the 468 Kit or just the bearing which is SKF7305 or 3540???? I really need to get it right the first time. And yes, I have search extensively. Please, any help would be very much appreciated. Thanks
Jason
Jason
