I noted that when I turn the switch on to start the engine the Red or ground wires through the battery get really hot and if I keep trying a fume start to come from the battery terminals and the battery run out of charge right away. I already verify the terminal connections and those are OK , Could be an issue with the solenoid ? How do a check to determine the source of the issue , any ideas or suggestions will be great.
