Changing Out Motor Question
tmyers921
I have a 89 Bayliner Capri Cuddy that has a 125 Force on it. I have the chance to install a 1974 Mercury Thunderbolt 850 on this boat.
My question: Will this 850 be big enough to move my boat?
Any Pointers?
:rolleyes:
verado7
Re: Changing Out Motor Question
well the 850 is 85hp so you will notice a difference it will move it though question is how long is the boat and how heavy -
tmyers921
It's 19 ft and I would say about 2000lbs..........
Faztbullet
If you have a Force 125 it is 1984 or newer and is a "prop rated" engine meaning it has 125hp at prop, the 1974 850 is "power head" rated so it is only about 75hp at prop. It will work if needed but will have to to propped low to plane out boat and still speed and skiing are going to suffer badly , I myself wouldnt put anthing less than 100hp on it(boat).
tmyers921
UPDATE UPDATE UPDATE:
Just In:
I recieved a call from a guy who has a 125 Force. He said he started it about a year ago and it ran fine on muffs. I asked him if he did a compression test and he said he would and call me back,,,,,,,,,well he did and said top to bottom is 150,,,,,150,,,,,150,,,,,,140.
What to do ,,,what to do?????
I can get this motor for $500.....
Help,,,,,,,
What would you do?:confused:
verado7
for 500 bucks -go for it - you would be disapointed with other one .
