Where is the ice forming?
I have run o/b's from the high 90 degree range to well below freezing, and never had this happen or even heard of it happening.
Never, you'd think have a cowl on with the 120F+ temp of a powerhead would keep things nice and warm in there. It has to do with temp and humidity but normally at much lower temperatures than 70+F.
Question- has that motor got an airbox on it still?
Did you just get the motor or have you had it for a while, when did it start doing it. When you rebuilt the carb did you put in a kit, pop out welch plugs, soak it and such. When I think of carb freezing I think or artic cat skidoo's and Cessena's. The Florida boys on the forum seem to have the issue too, maybe they have a cure.
i never thought anything of it. it doesnt affect the performance and i never get ice just water that condenses because it is cold around the carb body.
it is 100% normal, the flow of air cools the carb, high humidity, creates condensation, freezes on cold carb. i have had it happen even here in Florida.
This is a first Ive ever heard of this. Im interested in reading more about the why's and hows. Maybe you should take a temp gun with you and see what the temp around the carbs are.
I had that happen once. I had problems with my starter rope on my 1955 25hp johnson. I took the cover off to take off the manual starter and after
starting it with the rope I headed back with the cover off and I actually watched the carb as it froze up but that was in 30 degree weather during hunting season/
