dizzy_craig
- Apr 13, 2010
- 4
Absolutely no fire unless engine is warmed, either by sunlight with cover off, or as my uncle discovered, if you take a blow dryer to it... lol. This is really what he does to get it going everytime he takes it out. But don't think that was his first choice. He first replaced the coils, plugs and plug wires. When that didn't work, he figured out that when he had the top off for a while in the hot sun... it would start up and run great for the rest of the day, even though he had accomplished nothing with his tinkering. He then took it to a local boat shop, who called and informed him that there was nothing wrong with it. It had been in there lot in the sun all day. He told them to bring it inside early the next morning before it had time to warm up. They called the next day and said there was still nothing wrong with it. But sure enough, the next time he took it out.... same old problem. I'm thinkin it could be the switch box. He's been blow drying the area around the left coil, which sets right behind the "black box", which sets right behind what I believe is the rectifier??? I've tried disconnecting the black\yellow wires, which accomplished nothing... Any help with this puzzler would be greatly appreciated... Thanks much! Hopefully?
