superbenk
- Oct 27, 2008
- 2,033
Took the boat out for the first time over the weekend & most everything worked perfectly!! One issue I noticed was that cruising at high RPM (~4000-4500RPM), things would run great most of the time, but occasionally there'd be a very slight hesitation for a second and then it'd be fine again. It was extremely subtle, but I could hear it and just barely feel it. It didn't register much change on the tach, though.
I'm thinking it might be something with timing or dwell adjustments or maybe fuel related (water, gunk, etc.) from sitting over the winter. I did use Stabil in the tank when I laid it up. Anything else I should check?
